Community Member
¿How to manage/unmanage a device just in the DFM module?
I have Cisco Prime LMS 4.1.
I am looking for the way to manage/unmanage one, or a group of serveral, devices just for the DFM module. I've found the way to manage/unmanage the devices completely (for all modules), but that is not what I need.
Any ideas?
Thanks very much.
1 ACCEPTED SOLUTION
Unfortunately from LMS 4.x it is not possible to remove device individually from modules.
Either all or none. Though you can re-submit perticular devices. If any device is unmanaged/suspended it will be for all the modules.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
-Thanks
Vinod
Community Member
Thanks for your early answer.
238
