Webcast-Catalyst9k
How to monitor network traffic witrh LMS
Can anyone tell me how we can monitor network traffic using LMS.Our concern is to monitor machines which may be spreading virus or SPAM in the network.Is there any way we can check this in LMS??
1 REPLY
Silver
Re: How to monitor network traffic witrh LMS
LMS does not do this type of thing.
DFM will be able to see that your backbone might exceed it traffic limits in case of such an event.
IMHO the tools that hit the network with SNMP polls on all interfaces and keep track of the results so it can tell you the ports that have started to exceed their "normal" traffic use quite a bit of bandwith and cpu and are a high price to pay for this type of info.
And if the virus doesn't cause are real flood you won't find it with these tools.
Cheers,
Michel
201
