How to reconfigure PI 1.3 HA appliances?
rgomes
I have configured both PI 1.3 HA on the lab for comissioning before install with production IPs, GW, DNS and passwords.
What is the proper procedure to change all parameters to production values:
1 - Changing config with CLI commands
or
2 - Running setup again
I am not sure if it's possible to change all parameters via CLI commands and also not sure
if is possible to run setup again, as I see on the very first setup message showing:
Appliance is configured
Installing applications...
Installing NCS ...
Allthough there is a CLI command "write erase" that clear all configuration I dont know if
it's safe to write erase and run setup again.
If noneof the options above are correct and safe I would need to load the DL-DVD with the ISO image of PI 1.3.
Any help is appreciated
rgomes
So far I could change the install parameters making changes on the configuration and using cli commands
for change the root and ftp user passwords.
By the way the correct username for the ftp user is ftp-user, this is not documented on any manual.
Now I am having trouble to apply the PI_1_3_0_20-Update.4-16.tar.gz patch on the secondary.
