How to recover purged syslog
Dear all,
By mistake, I purge some syslog but the syslog file is available, how can I recover the log then I can generate according reports? Thanks in advance.
1 REPLY
Re: How to recover purged syslog
You can't. Once syslogs are purged from the database, there is no way to run reports on them or re-add them to the database. You will need to run search operations through the syslog.log.
122
