How to transform simple Tcl script into EEM policy?
I have the following simple Tcl script which can be executed from CLI using command "tclsh filename.tcl":
# --- start of script ---
typeahead "\n\n"
exec copy nvram://startup-config ftp://username:password@10.1.1.1/backup-confg
# --- end of script ---
Now I would like to turn it into EEM policy which will copy startup-config to FTP server each time user types in command "copy running-config startup-config". I created directory flash://tcl/, copied my script there and entered these commands:
event manager directory user policy flash://tcl/
event manager applet archive
  event cli occurs 1 sync no pattern "copy running-config startup-config"
How should I complete my configuration and how should I change my script?
Thanks in advance!
Re: How to transform simple Tcl script into EEM policy?
You don't need your Tcl script anymore, nor do you need the event manager directory user policy command.  This applet should do what you want:
event cli pattern "copy running-config startup-config" sync no
action 1.0 cli command "enable"
action 2.0 cli command "copy start ftp://username:password@10.1.1.1/backup-config" pattern "Address"
action 3.0 cli command "10.1.1.1" pattern "Destination"
action 4.0 cli command "backup-config"
Thank you very much.
I'll try this solution as soon as it's possible.
Thank you once again, Joseph.
Your appllet has solved my problem, although I had to customise it a little to make it work on my router Cisco 2851 (IOS Version 12.4(18)):
  event cli pattern "copy running-config startup-config" sync no skip no occurs 1
  action 1.0 syslog priority notification msg "Trying to upload running-config to FTP server..."
  action 2.0 cli command "enable"
  action 3.0 cli command "configure terminal"
  action 3.2 cli command "file prompt quiet"
  action 3.4 cli command "end"
  action 4.0 cli command "copy startup-config ftp://user:password@10.1.1.1/backup-config"
  action 5.0 cli command "configure terminal"
  action 5.2 cli command "no file prompt quiet"
  action 5.4 cli command "end"
You have EEM 2.1.  The ability to do interactive commands in applets was added in EEM 2.3.  You would either need to use an EEM Tcl policy, or do what you've done and configure "file prompt quiet".
576
