Community Member
How to troubleshoot routers
I have some questions concerning the process of troubleshooting the hardware perfomances of routers.At
my company I have to deal with some routers that have crashed during normal operations.Sometimes I can
guess what the problem is by checking the crashinfo file but sometimes there isn't such a file.So I'm just
enabling logging on them and let them pluged in but with no traffic to forward.Most of the times I do not get
any error messages but when they return to their sites they crash again when they have to deal with traffic.Is
there any method I can use to simulate traffic in my lab(maybe a packet generator?) and to see how the
equipment is copping with a more sustained utilisation?
1 REPLY
Re: How to troubleshoot routers
In addition to ur action plan which u have chalked out i would like to add few suggestions in approaching the crash issues..
The better tools will be something inline with MRTG or PRTG which can be very much useful to find out the amount of traffic being handled by the router interface.
you can poll up the router and get the bandwidth analysis in regular intervals.
Also you can monitor up the memory and CPU utilisation using those tools.
you can use show version command too to find out the possible cause for the last reload mostly the ios code mite be affected with some bugs which may be aso a possible reaso.
that can be overcome with an ios upgrade to a latest GD version available..
you have got enough links over here in cisco site which mostly deals with router crashes,buffer or memory leaks which also results in crash..you can use them up to find out exactly in which category ur case falls in ....
regds
116
