How to uninstall LMS 4.0.1?
I installed LMS 4.0 and then LMS 4.0.1 but I have to come back to 4.0, does anybody know how can I uninstall LMS 4.0.1 without having to uninstall the whole LMS and install it again?
Kind regards.
  • Network Management
Hall of Fame Super Silver
I don't believe there's a rollback / revert option. If you uninstall it will remove all of LMS.
You could do a backup of your data first so that is is available to restore onto the re-installed 4.0.
Puff! I knew this would happen...
Anyway, thank you very much!
To uninstall both LMS all at once and quick use the clean_system.exe
Cheers,
Michel
275
