02-19-2010 02:35 PM
We need to archieve configuration for Cisco ASA 5500 series appliances.
We have Cisco works LMS 3.0.1.
Device package installed is 4.2
Any help would be appricated.
Thanks in advance.
Samir
02-19-2010 06:51 PM
You have the latest version of the ASA package, so there shouldn't be a problem supporting these devices in RME. what errors do you get performing a Sync Archive on these devices?
02-24-2010 02:41 PM
Just for the knowledge, can you tell me how cisco works archieve configuration, means via http or tftp ?
Waiting for your reply.
thanks,
Samir
02-24-2010 10:07 PM
For the ASA, neither will be used. Instead, RME will login to the ASA via either telnet or SSH (depending on the configured transport protocol order), and issue the show running command to collect the configuration output.
02-25-2010 12:15 PM
Hi ,
Thanks for your answer.
Right now we are using TACAS to login in to the ASA. That means we need single username and password to login via
Cisoworks. Am I correct ?
thanks,
Samir
02-25-2010 09:39 PM
Correct. You must edit DCR under Common Services > Device and Credentials > Device Management, and add a username/password for your ASA devices. RME should then be able to collect the config.
