Community Member
HTTP not working to NAM module
I am working with a client whom has an NM-NAM module installed in their 3825 ISR. I can ping the address of the NAM, as well as connect to it via telnet. The issue at hand is that it will not allow any connections to the web based Traffic Analyzer . I have it configured according to the Cisco documentation. here is the configuration...
# ***** NAM configuration *****
# Time: Fri Aug 7 18:35:19 2009
# Version: 4.0(1)
ip interface internal
ip address 172.31.200.2 255.255.255.0
ip host "LOMPLSNAM"
ip domain "odec.com"
ip gateway 172.31.200.1
ip broadcast 172.31.200.255
ip nameserver 192.168.1.53
ip http tacacs+ disable
web-user
user-name kmelton
account-mgmt enable
system-config enable
capture enable
alarm-config enable
collection-config enable
encrypted-password "NWU3Y2YxYzMzOTI5NjgyYjc2ZWEwYjQ1ZWU4NTNkNDVlZTk5NmQ3Zgo="
exit
ip http port 80
ip http secure port 443
ip http server enable
ip http secure server enable
I have reloaded the NAM twice, but it does not help.
Re: HTTP not working to NAM module
It looks like you have SSL enabled. Try:
https://172.31.200.2
Community Member
Yeah we had tried that and it still does not answer. We even had a tech try locally on the same network where the NAM is and we cant get to it via https or http. Still answers just fine to SSH and telnet though.
It sounds like an issue with the http server that persists even when the nam reloads.
Try:
1. Change the port of http: ip http port 8080
2. Disable and re-enable ip http: ip http server disable, ip http server enable.
There may be a firewall l in between that could block ports 443 and 80
I would suspect a firewall or access-list, then. If you post a show tech from the NAM, I can confirm if the http server is listening on the required ports, but I would bet that something is blocking both tcp/80 and tcp/443 to this device.
268
