https/ssl with CiscoWorks Browser
Is is possible to configure secured CW browser access using https or ssl certificates?
1 ACCEPTED SOLUTION
Re: https/ssl with CiscoWorks Browser
There are no such things as CS 2.5 and 2.6, so I will assume you mean CS 3.0 for LMS 2.5 and 2.6. For LMS 2.2, you can only enable SSL mode if you do not have DFM installed. To enable SSL mode, go to Server Configuration > Administration > Security Management > Enable/Disable SSL.
For LMS 2.5 and higher, SSL can always be enabled. To do this, go to Common Services > Server > Security > Browser-Server Security Mode Setup.
Absolutely. What version of CiscoWorks are you using?
Thanks for the reply!
We are using CW Common Services 2.2, 2.5, and 2.6 on Windows 2000 and Solaris servers.
Thanks again,
Bob Schlifke
351
