HUM 1.0 unable to compile ISDN-MIB
I have installed evaluation copy of HUM 1.0 in LMS 3.0 to try if it can monitor ISDN PRI DS0 usage on a Cisco 3845 voice gateway. I downloaded the ISDN-MIB and all the dependencies from Cisco.com but when I complie them according to the order specified,I got "Unable to load the MIB file. Either you are trying to load an invalid MIB file or the dependant MIB files are not available in the path" when I reach RFC1213-MIB and ISDN-MIB. What can I do to get this issue resolved? does it mean I have to buy license to the HUM?
best regards,
Abebe Amare
Network Engineer, VivaCell
1 ACCEPTED SOLUTION
Re: HUM 1.0 unable to compile ISDN-MIB
Try loading this version.
You need to make sure that all of the required MIBs are loaded first. For the ISDN-MIB, those are:
SNMPv2-SMI
SNMPv2-TC
SNMPv2-CONF
IF-MIB
IANAifType-MIB
RFC1213-MIB
RFC1155-SMI
RFC-1212
SNMPv2-MIB
If, after loading those, you still see an error, check the upm_base.log, and the reason for the error will be seen there.
Dear JClark,
Thank you very much for your invaluable input. I loaded the MIBs you mentioned except RFC-1212.Getting the right non-Cisco RFC MIB proved difficult. They differ depending where you get them. I loaded RFC-1213 without loading RFC-1212, which should be a dependency. But I could not load the ISDN-MIB. I have attahced the upm_base.log file.
Dear JClarke,
Thanks a lot. That solved my problem.
Best Regards,
Abebe Amare
153
