HUM and CSM in the same server?
is it possible to install HUM+CS and CSM in the same server?
Regards.
1 ACCEPTED SOLUTION
Blue
Re: HUM and CSM in the same server?
Yes, if CSM's CS is the same version as that of HUM's. For example, in order to maintain Cisco support:
"We do not support installation or coexistence on one server of Security Manager 3.3 and any release of Common Services earlier than 3.2. Nor do we support coexistence with any third-party software or other Cisco software, unless we state explicitly otherwise in this guide or at http://www.cisco.com/go/csmanager. "
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.3/installation/guide/servprep.html
1 REPLY
Blue
130
