Community Member
HUM Interface Report
Hello, I have recently discovered the HUM Interface Report, however I have found that it only reports data for the last 1 hour. Is it possible to configure this report for a custom time frame. I access the report from cisco view, and right clicking on a port on the switch. Is there a screen somewhere else that I can launch the report with a different time frame, like the last week or last month??? Thanks
1 REPLY
Re: HUM Interface Report
The interface report is a quick report.
You can change the settings for polling the quick report from :
Admin-> System Preferences-> Quick Report Schedule.
Latest HuM with LMS 3.2 gives you the granularity to change the polling per report and not for all the quick reports as on earlier versions.
112
