02-06-2009 12:02 PM
I am trying to set up some pulling of CPU, memory utilization and environmental polling. I have the pollers set up and used the appropriate instances, but my portlet says that there is no data to display. Trying to figure out why.
02-06-2009 01:18 PM
What version of HUM? What are the statuses of your pollers?
02-06-2009 01:22 PM
version is 1.0 and my pollers are active. I have one poller polling several differnet templates and instances. Some of them, seem to be getting info just fine, others do not.
02-06-2009 01:28 PM
Did the portlets ever show data available? Or have they always reported no data since defining the pollers?
02-06-2009 01:49 PM
always reported no data since defining the pollers, for a few templates I am using, not all of them.
02-06-2009 01:58 PM
How are your problem pollers defined? What templates are you using?
02-06-2009 02:06 PM
I have one poller called core switch, I am using the cpu utilization, temp, interface utilization and memory utilization templates. I have all available instances checked.
I then have portlets set up to show top N cpu utilization, top n memory, top N interface utilization. My top n interface utilization is showing me the info, but the others say no data to display. This poller is the only one using the cpu memory & environmental temp templates so it has to be among the top N cpu because it is the only one.
02-06-2009 04:02 PM
ok, I just noticed that my memory utilization started showing data. Several hours after I configured the pollers. Does it just need to poll a certain amount of data before it shows results?
02-06-2009 07:18 PM
The HUM portlets should start showing data after two polling cycles.
02-06-2009 07:46 PM
that is not what is happening. Also, my memory stats disappeared and now says that there is no data to display.
02-06-2009 07:48 PM
Please post the HUMPortal.log.
02-09-2009 10:35 AM
The file is 7 meg in size. Each time I try to attach it, I get a time out and page cannot be displayed.
02-09-2009 10:44 AM
The file is pure text. Just compress it, and you should be able to post it.
02-09-2009 10:51 AM
02-09-2009 10:56 AM
The underlying queries are not finding any data. Go ahead, and delete your current poller, and recreate it. We've seen cases where this can get the real-time data to show up in the portlets.
