Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
HUM Whitescreen, all portlets disappered from main window
Since upgrade from 3.0, now using LMS3.1 HUM get a Whitescreen, all portlets disappered from HUM main window. Administration sites of HUM are still reachable.
LMS is in ACS mode and HUM has been registered to ACS(4.0) server as well. What can we do?
thx for hints in advance, Steffen
Re: HUM Whitescreen, all portlets disappered from main window
Can you manually add back the portlets to the HUM view by clicking on the + icon in the upper right-hand corner?
thx for quick reply. Yes I will do that tommorrow at customer site.
problem solved
111
