Community Member
HUM
I have installed HUM evalauation it installed sucessfully i have seen in the common services but i can't see HUM in LMS portal page.
1 ACCEPTED SOLUTION
Re: HUM
Make sure you are looking at the LMS portal and not My Portal or CiscoWorks Portal.  You should see a HUM view tab.  Note, depending on the screen resolution, you may have to click on an arrow icon to view other portal views.
1 REPLY
Re: HUM
157
