I deleted a device from RME, can't re-add it
I had one switch that would sit in the "pre-deployed" status and I could never get it into the "normal" status. I deleted it, thinking I could re-add it. When I go in to add the device I deleted, the device is not available to add.
If I go back to Common Services or Campus Manager, I have all of my devices listed, including the one I deleted from RME. How do I get that one device imported back into RME?
1 REPLY
Re: I deleted a device from RME, can't re-add it
disregard, Apparently the "Add" option I clicked before was not the right "Add" button.
215
