03-13-2014 12:44 AM
I am trying to collect jitter information of cisco Routers which are added in Cisco LMS
I have configured collector icmp jitter for them but somehow no stats are visible in lms and its says in IPM that u have no jitter collectors configured.
Do i need to enable anything on the Router as well to export stats to LMS ?
03-13-2014 02:30 AM
can you share the screen shot of the collector that you have created ?
did you check and find any IPSLA config on the device after configuring the IPSLA collector ?
Thanks-
Afroz
03-13-2014 04:26 AM
Thanks for the reply .
I have configured icmp collector through GUI in cisco LMS
and for the router i have enable ip sla for icmp jitter
config of Router is :
ip sla 1
icmp-jitter 10.80.10.55 source-ip 10.11.0.89 num-packets 100 interval 40
frequency 50
ip sla reaction-configuration 1 react jitterAvg threshold-value 5 2 threshold-type immediate action-type trapOnly
ip sla schedule 1 life forever start-time now
logging 192.128.10.20
snmp-server view default iso.0.8802 included
snmp-server view default iso.1.2 included
snmp-server view default org.111 included
snmp-server view default internet included
snmp-server community abcd RO
snmp-server community efgh RW
snmp-server community public view default RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 192.128.10.20 abcd
Apart from this do i need to configure anything else on Router ?
03-13-2014 05:43 AM
Hi ,
No more configuration is needed.
first define the Operations and then create the collector.
go to Internetwork Performance Monitor > Collector Management > Collectors.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_internetwork_performance_monitor/4-2/user/guide/IPM4_2ug/ipmopmg.html
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_internetwork_performance_monitor/4-2/user/guide/IPM4_2ug/ipmclmg.html
select your collector and click view , share the screen shot for the same.
Thanks-
Afroz
***Ratings Encourages Contributors ***
03-13-2014 05:54 AM
03-13-2014 06:45 AM
for ICMP jitter operation ,configuring responder is not required.
Are you facing issue with only this device or all of them ?
what is the output of the below command on your device :
"show ip sla monitor application"
OR
"show ip sla application"
Is IPSLA is supported on this device ?
and " show license"
share the above outputs
Thanks-
Afroz
03-13-2014 10:14 PM
IP Service Level Agreements
Version: Round Trip Time MIB 2.2.0, Infrastructure Engine-II
Time of last change in whole IP SLAs: *07:35:21.730 UTC Thu Mar 13 2014
Estimated system max number of entries: 27977
Estimated number of configurable operations: 27976
Number of Entries configured : 1
Number of active Entries : 1
Number of pending Entries : 0
Number of inactive Entries : 0
Supported Operation Types
Type of Operation to Perform: dhcp
Type of Operation to Perform: dns
Type of Operation to Perform: echo
Type of Operation to Perform: frameRelay
Type of Operation to Perform: ftp
Type of Operation to Perform: http
Type of Operation to Perform: icmpJitter
Type of Operation to Perform: jitter
Type of Operation to Perform: pathEcho
Type of Operation to Perform: pathJitter
Type of Operation to Perform: slm controller
Type of Operation to Perform: slm frame-relay interface
Type of Operation to Perform: slm frame-relay pvc
Type of Operation to Perform: slm interface
Type of Operation to Perform: tcpConnect
Type of Operation to Perform: udpEcho
Type of Operation to Perform: voip
IP SLAs low memory water mark: 38288719
The device is a Cisco 1841
03-13-2014 10:35 PM
Thanks for sharing it.. devices side it should not be a problem.
Is your devices managed properly , I mean inventory and configuruation backup >they are sucessfull.
If everything is fine then try to delete the existing opeartion and collector and re-configure (operation >>collector).
Thanks-
Afroz
03-15-2014 12:13 AM
Still not working .. the device is accessible from LMS , aso i configured / reconfgured but still no success
03-15-2014 12:18 AM
can share the CDA job result of that device. { Inventory > Job Browsers > Device Credentials Verification}
Thanks-
Afroz
03-15-2014 02:43 AM
03-15-2014 03:35 AM
by mistake you have attached a wrong screen shot , I need the job result of device credentilas verification of this device [Inventory > Job Browsers > Device Credentials Verification].
Thanks-
03-15-2014 04:04 AM
03-15-2014 04:29 AM
03-18-2014 02:42 AM
