IDS: How to monitor?
ahpark78
HI,
Just wanna to know what is the good approach on IDS management?
Any ideas?
tks
ken
Collin Clark
Do you mean product or policy? If you're talking product, CS-MARS hands down. Policy needs to come from the security team.
Ken,
There are couple of ways you can monitor IDS/IPS. IEV - IDS Event Viewer - can be used if you have less than five sensors to monitor. If you intend to monitor more than five sensors or looking for more functionality then CS-MARS - Cisco Security Monitoring, Analysis and Response System - is what you need.
Sundar
