Any experienxe what is best way in RME to save old config backups if device ip address change. Now it looks like that if device ip address change i have to delete device from RME and CS and start device discovery to find it again with new ip address. After that old config backups disappear. Also i cant find syslogs with old ip address from RME anymore. Is there a way to change ip address for switch without loosing old config backups and syslogs. Name will be the same.
Juha
