In Cisco Security Manager is there a way to manage crypto default peers
I try to find a way to use crypto default peer feature in Cisco Security Manager.
I've tried manual modifications: CSM adds a second configuration to bypass the manual modification.
I then tried to declare backup routers as regular end-points in the IPsec VPN, it solved the password management, but the "default peer" issue is still there...
As crypto lines are generated dynamically, I can't use flexs...
Has someone a good idea ?
117
