Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Incorrect community on a Router 4500
i am running openview network node manager extended topology, and every time when the extended topology run, i get traps from one router, which says incorrect community strings. I see, when i to a trace, that openview uses the community string readstring@1. Why it the
@1 added? Is this a problem from the router or from node manager?
Re: Incorrect community on a Router 4500
@1 usually refers to community string indexing. In this case it usually refers to a VLAN, VLAN 1.
However, if the community strings on the device have an @ character then things will get messy as the NMS/device will assume indexing and not that its @ in the string.
I have no @ sign in my community string and have not configured any vlans on the router. So i think, that the HP nodemanager ask for informations which are not on the router. My problem is, does the router send informations back to the nodemanger when it is queried with the normal community string, or is there a problem in the nodemanager. I use version 7.51 ET. The error is only seeing, when the nodemanger does a extended discovery.
95
