Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Index in CISCO-STP-EXTENSIONS-MIB
does someone know how get the ifindex when doing an snmpwalk on the stpxFastStartPortMode OID(1.3.6.1.4.1.9.9.82.1.9.49)?
I'm looking for the connection to the ifdescr (1.3.6.1.2.1.2.2.1.2.10101), which tells me what's the interface (e.g. GigabitEthernet0/1).
These indexed differ on a 2960 but are the same on a 2950.
1 REPLY
Re: Index in CISCO-STP-EXTENSIONS-MIB
The stpxFastStartPortTable table is indexed by dot1dBasePort. To map this value back to an ifIndex, you need to use dot1dBasePortIfIndex. That object will be indexed by dot1dBasePort, and will provide you the ifIndex of the associated port.
248
