I install actually LMS2.5.1 and I have a problem with cwjava.exe.
After the installation of Common Service, I reboot the 2003 server, and I receive this error cwjava.exe Application error: The application failed to initialize properly (0xc0000135) clic on OK to terminate the application.
After this first message I have three oser message:Unable to locate dbmonitor.exe; Unable to locate diskWatcher.exe and Unable to locate rvrd.exe.
Do you have any answer about this problem ?
Hervé
