03-29-2010 11:49 PM
We er evaluating LMS 3.2. LMS is ok and running on win 2003 server for over five weeks. Now when I try to install HUM 1.2 from the same DVD, the installation asks a list of processes to be closed in order to install HUM. I have closed all programs and run "net stop crmdmgtd" to stop all processes. Got a confirmation that daemon was stoped but did not help to continue the HUM installation anyway. I have checked in the task manager but the name of these processes are not quite the same. CiscoWorks is also closed before trying to install HUM. I will appreciate for any tips. Thanks.
03-30-2010 12:02 PM
Put the daemon manager from automatic to manual.
Reboot the box
Launch the CD or installer.
Put the daemon manager back to automatic
Cheers,
Michel
03-31-2010 01:37 AM
Thanks Michel!
Is there a way to skip or disable the data backup step in order to install HUM on LMS 3.2?, (Daemon manuel)
Because it gives me data backup error. This error did not show up when I was trying to install HUM with Daemon on auto.
Greetings
Tesema
03-31-2010 01:49 AM
Yes Tesema,
Start it with the /NOBACKUP option
Cheers,
Michel
03-31-2010 02:32 AM
Perfect, thanks!
Appreciated.
Greetings
Tesema
