Webcast-Catalyst9k
Interface description
I want to change interface description for more then 2500 ports for my Cisco devices.
I am hunting for a SNMP based tool which can solve my purpose.
Which can list all the ports of the devices along with the interface description & can be edited through the GUI.
So that I do not need to login into each device via telnet & go on to every interface to change the description.
Thanks in advance.
1 REPLY
Re: Interface description
I have found solarwinds configuration manager which will accomplish the task..
Mayur
395
