Community Member
Interface Modules in CiscoWorks LMS 2.5
Is there a way to tell through CiscoWorks (like with a report) what typ of gigabit modules are in a bunch of different switches? We have the 1000Base-T and the GigaStack modules and was wondering if I can find out which switches have the GigaStack modules in them... Any Ideas?
Re: Interface Modules in CiscoWorks LMS 2.5
Hi Ken,
i cannot proof this in my small test environmet cause my "larger" switches are used for an test by my colleagues.
But i guess it might work with the RME Report Templates.
Try this:
"RME -> Reports -> Costum Report Teplates"
Press the Button "Create"
Then tick Inventory -> Next
Give a Name and use public -> Next
Have an eye on the next window:
(For the first Line of the rule you do not need a "Association")
Try for
Inventory Group: Module
Attribute: Model Name
Operator: Contains
Value: All
Press the Button Add and then next.
Confirm the last window with "Finish"
Now change to RME -> Reports -> Report Generator"
Choose as "Application" "Inventory" and in "Select a Report" scroll down the list and use the generated Report.
I guess the next window is self-explanatory.
If this does not work for you try the SNMP variables starting from OID
Us the Cisco SNMP Browser to find the correct entry for your modules:
With this information aou might write a script which triggers your switches and collect the wanted information.
I hope the first mentiones solution via RME Reports works. Maybe you are in need to play something around with the parameters.
Best regards,
