You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
intervlan rt
The intervlan routing can be done with also Catalyst 2950 ? or is limited to 3550 and higher?
Jorge
  • Network Management
1 REPLY
Re: intervlan rt
2950 is a simplisitic L2 Switch which cant serve your purpose of configuring Intervlan routing.
The other way around 3550 can do that which falls into L3 switch family even 3500XL dont have the inter vlan routing capability..
For inter vlan routing you need to have a L3 Switch or router to do that for u ..
regds
101
