Community Member
Inventory and configuration for some models is failed
The fetch configuration and inventory is failed for below devices:
1-Cisco Catalyst 2948G-L2 Switch with WS-C2948 Software, Version NmpSW: 4.5(3), System Bootstrap Version: 5.4(1)
2-Cisco Catalyst 4003 Switch with WS-C4003 Software, Version NmpSW: 4.4(1),System Bootstrap Version: 4.4(1)
We have CiscoWorks LMS 2.6 RME 4.0.5 with type NON-ACS and AAA Mode Setup: TACACS+
After troubleshooting the problem, when I telnet the device, I can access it as user privilege only then enable password by local enable password
When I changed device Credentials of enable password in DCR, I can fetch configuration but still the inventory can't be fetched.
Re: Inventory and configuration for some models is failed
Is there an error you are getting on inventory colletion? We will collect the inventory via snmp.
Community Member
No, just failed to collect invetory
142
