Inventory Failed for select devices: RICS0001 Internal Error
LMS: 2.6
CMS 3.0.6
DFM 2.0.12
RME 4.0.6
CV 6.1.5
5 - 3550 with IOS 12.2(25)SEE2 or newer
1 - stack WS-C3750G-12S 12.2(25)SEE2
1 - stack WS-C3750G-48TS 12.2(40)SE
Attached is ic_server.log
1 ACCEPTED SOLUTION
Re: Inventory Failed for select devices: RICS0001 Internal Error
You will have to talk to entitlement about that. If your Service Request makes it to a TAC engineer, you should be able to get the patch.
You need to increase the SNMP timeout for 10.49.1.62, 10.49.1.66, and 10.51.17.254 under RME > Devices > Device Management > RME Devices > Edit Device Attributes. Start with 10 seconds, and go up if needed.
It looks like 10.49.1.95, 10.49.1.103, 10.49.1.84, 10.49.1.200, 10.49.1.60, 10.49.1.111, and 10.49.1.60 are affected by my bug CSCsm97530. A patch is available by contacting the TAC.
It looks like 10.49.1.102 and 10.49.1.120 are unreachable via SNMP from the RME server.
It looks like 10.51.14.246 might be a 2950 or 3550 running less than 12.1(19)EA1 code. This switch will need to be upgraded before inventory collection will work.
Can I get the patch even if I don't have the product under contract?
The original contract ran out in 08 and we did not renew.
148
