IOS EOL Characters
bmcgahan
Does anyone know what character codes IOS uses for EOL in show
output? The standard "\n" and "\r" chars are used for some lines, but
not all. The regex character "$" is catching something more than "\n"
and "\r" and I need to find out for some scripting purposes:
Rack1R1#show run | exclude \n
boot-start-marker
memory-size iomem 10
ip cef
Rack1R1#show run | exclude \r
hostname Rack1R1
no aaa new-model
ip cef
no ip domain lookup
Rack1R1#show run | exclude \r|\n
ip cef
Rack1R1#show run | exclude $
Rack1R1#
Brian McGahan, CCIE #8593 (R&S/SP/Security)
bmcgahan@internetworkexpert.com
Internetwork Expert, Inc.
http://www.InternetworkExpert.com
Toll Free: 877-224-8987 x 705
Outside US: 775-826-4344 x 705
24/7 Support: http://forum.internetworkexpert.com
Live Chat: http://www.internetworkexpert.com/chat/
Joe Clarke
I have no problem with "show run | exc $" but try out:
show run | exc [\r\n]?$
That sequence also works for me.
Hi Joe,
Thanks for the reply. The issue isn't that $ isn't matching the EOL, it's that $ is matching additional EOL chars besides "\n" and "\r". I need to find out what those additional characters are.
Brian
The only two characters used are ASCII \015 (carriage return) and ASCII \012 (newline) (at least on my test 7206). There appears to be a problem with the exclude command, though in that it is not matching what it should when character classes are included.
If you're device is running 12.3(2)T or higher, you can use TCL to scrub your config looking for other EOL characters. Here is a quick and dirty script:
set output [exec "show run"]
set fmt [string repeat "%c" [string length $output]]
set char_lst [scan $output $fmt]
foreach char $char_lst {
if { $char < 32 || $char > 126 } {
puts $char
This will print the decimal values of any non-printable character. In my test, I only see 10 and 13.
