05-31-2006 02:05 PM
which IOS supports netmask 255.255.255.254
06-01-2006 05:44 AM
I presume you are talking about using 31-bit prefixes on IPv4 point-to-point links.
Use the Cisco Feature Navigator and search by feature.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
The feature you want to look for is 'Using 31-bit Prefixes on IPv4 Point-to-Point Links' You can then start to filter down to find your exact image
--Phil
Please rate useful posts
06-01-2006 06:38 AM
The feature was introduced in 12.2(2)T and mainlined in 12.2(28)SB. See the feature guide for 12.2T: http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087aeb.html
Hope this helps, please rate helpful posts.
