%IP-4-DUPADDR: not showed on the gestion platform
HI all,
The thing is... our gestion platform (which receiveds the SNMP traps) don´t shows dupplicated ip addresses in the network, I mean... ie. we have a 6500 box and we can see the following line in the log: May 30 20:03:35: %IP-4-DUPADDR: Duplicate address 10.9.0.124 on Vlan3003, sourced by 0015.2bb4.fa45
I understand this box has detected a device in the network with an ip which is already configured on itself, but we don´t know the way to tell the 6500 box about sending a trap to the gestion platform...
Has anyone any idea about it?
Thanks in advance.
Silver
Re: %IP-4-DUPADDR: not showed on the gestion platform
Hi Enrique,
do you have logging to a syslog server enabled?
For IOS: logging trap
and for CATOS: set logging server
If a IOS "logging trap errors" is set the warnings the the Dup_IP are not sent to the syslog server.
Only messages from Level 3 down to 0 are sent (emergencies, alerts, critical and errors)
You will find a list of levels here:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00801cde77.html#58814
(Note: This is for another switch, but the levels are accurate)
If you want the level 4 messages sent to a syslog server you have to issue the command
IOS: logging trap warnings
CATOS: set logging server 4
And be sure logging is enabled.
Hope that helps
Best regards,
Frank
HI Frank,
We have a login level informational, so, it includes from level 6 to 0, Am I right? then... the ip dupplicated address alarm should be sent to the syslog server...
SWPE01#sh logging
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 635 messages logged
Monitor logging: level debugging, 303 messages logged
Buffer logging: level debugging, 637 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 352 message lines logged
Logging to 172.26.26.98, 352 message lines logged
Logging to 172.26.26.99, 352 message lines logged
186
