IP-6-UDP_SOCKOVFL:UDP socket overflow
I have a question:
One of my C65 is getting in trouble with the following message:
%IP-6-UDP_SOCKOVFL:UDP socket overflow from Source IP: xxx, Destination port: 161
A show netstat udp shows this:
sh netstat udp
udp:
0 incomplete headers
0 bad data length fields
0 bad checksums
177940 socket overflows
382 no such ports
because of that problem with udp p161 my polling NNM always detects this as a node down, which is really annoying.
Do you know how to clear the buffers. I will not be able to reload the Box, its production.
cheers
yves
Re: IP-6-UDP_SOCKOVFL:UDP socket overflow
hi
Do find the reason and the recommended reason to avoid the same in the future..
%IP-6-UDP_SOCKOVFL: UDP socket overflow from Source IP:[chars], Destination port:[dec]
This message indicates that all buffers for a UDP socket on the Network Management Processor (NMP) have filled up due to excessive UDP traffic on the administrative VLAN and cannot store additional traffic. [chars] is the source IP address and [dec] is the destination port number.
Recommended Action: Remove or block the source of the UDP packets to prevent further UDP packet loss. Note Kernel messages do not indicate a problem with system performance but should be reported to your technical support representative.
regds
Hi , I don 't think there is excessive udp traffic, not more than on all the other 50 boxes, and they work just fine.
I there a way to clear the buffers, or something thats help without implementing acls.
Because I need Port 161 on udp for Monitoring.
Red
What code are you running on your Cat6500?
We are running cat6000-supk8.8-3-3.bin
Red
Nevermind then, I was suspecting a known issue that is fixed in 7.6(1) and higher.
Check how many SNMP packets are hitting the switch, and their frequency.
567
