IP Address Management
Hi Guys,
Our company is getting bigger and bigger every day. It's almost hard to manage and keep track of hundreds IP addresses. Do you recommend any good and recommended IP address management tool which would have few handy features (searching, status etc)
Thanks.
Gold
Re: IP Address Management
We used IPTRACK
http://iptrack.sourceforge.net/
I works quiet good
M.
anymore recommendation? I've been playing up with this iptrack...looks like many settings need to be done in some complicated ways....which is bit hard to manage by a group of people. I wouldn't mind spending money on this if there's a good solution out there. Thanks
you might try Solarwinds Engineer Toolset.
it has an IP ADDRESS MANAGEMENT function and allows you to publish subnets to your web site, .etc
you could probably download their trial version and check it out.
larry c.
I have tried this too, but this is very basic, I need something more advanced , more like managengine Oputils IP Address management tool, but it comes with other tools that I don't need! Thanks for your reply.
119
