08-21-2008 12:26 PM
Device: 7206VXR with G1 network processing engine. 12.4(19)
Issue: "ip route-cache flow" command unexpectedly stripped from gig interfaces within a port-channel.
Changes prior to issue: added a VLAN to the router causing CPU load to increase from about 10% to 50-70% during working hours.
Does anyone know if there is a CPU threshold trigger to disable netflow exports?
08-27-2008 02:19 PM
You can remove events from the RMON log in the managed device
The following URL may help you:
08-27-2008 05:42 PM
Looks doable with EEM:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6815/whitepaper_c11-492226.html
If your IOS supports EEM's ioswdsysmon keyword, that's the ticket for pulling the trigger on CPU util threshold. If not, you can still key off the snmp value for CPU util (avgBusy1, avgBusy5, or a third one that escapes me).
