03-13-2007 01:33 AM
Greetings from Poland,
is there any chance to use virtual interface (i.e. loopback 0) for the IP SLA feature of cisco routers? I would like to set a public ip address for this interface and would like to test www, dns and my core network.
Thanks in advanced,
ZO
03-19-2007 06:40 AM
no, it not possible use loopback interface for IP SLA.
Try these links:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsla_c/hsoverv.htm#wp1062629
http://www.cisco.com/en/US/products/ps6602/products_qanda_item0900aecd8017bd5a.shtml
03-19-2007 08:54 AM
If you mean source the IP SLA probes from a loopback interface, this is certainly possible. For example, if you want to measure the latency between the device, and a WWW server, 10.1.1.1, and your loopback IP is 1.1.1.1:
ip sla 113
http get http://10.1.1.1/ source-ip 1.1.1.1
You can even specify a source interface name instead of an IP address.
