Community Member
IP SLA Detailed daily, weekly Report could not be found
Hello.
I use Cisco Prime LMS 4.2.1. When i generate IPSLA Detailed  UDP Jitter Report with granularity "Minute"  "Hourly" everything is OK, but when i with "Daily" "Weekly" i get this message: "Report could not be found". Report "Availability" and "Latency" generate well.
In IPSLA System summary i see again only "Availability" and "Latency" reports.
System Consolidation Daily Job generates every day. And inside job i can see that UDP Jitter rows is proccesed.
By the way, I can generate UDP Jitter report from CLI.
In Relise notes LMS 4.2 i saw open bug CSCtv11780:
An error message "Report could not found" is displayed when you generate a report using:
System: Management Type in the Report Attributes column, and
any other attributes, such as Location from System Inventory Group in the Rules for Attributes column.
Someone help me, please.
346
