08-25-2008 11:16 AM
I want to set up a HTTP test in CiscoWorks IPM to google as a standard latency test to the interent, but I am not sure how to set this up as a user defined test.
Any suggestions?
mike
Solved! Go to Solution.
08-25-2008 11:48 AM
First, you need an IOS device capable of performing an IP SLA HTTP operation. I'll assume you have added one to DCR, and it's managed by IPM.
Go to IPM > Collector Mgmt > Devices. Click Add Adhoc Target. Add www.google.com.
Go to IPM > Collector Mgmt > Operations and click Create. Give your operation a name, and select HTTP as the type. Adjust your latency values to taste. Click Next.
Enter / as the relative URL. Fill in any required proxy information. Click Next then Finish.
Go to IPM > Collector Mgmt > Collectors. Create a new collector. Choose your IOS source device. Choose the ad hoc target www.google.com. Then choose your newly created HTTP operation. Give your collector a name, and click Next then Next again.
Choose the collector type (either historical or real-time), then choose when you want it to run, and the poller settings. Click Next then Finish.
08-25-2008 11:48 AM
08-25-2008 12:09 PM
Thank you very much.
Mike
10-01-2008 05:00 PM
Hi jclarke,
Is the source router running IOS have to be configured with SLA or is this only applied on the target IOS?
My test collector is not showing real-time stats. Does this take a few hours to generate a report?
10-01-2008 08:59 PM
Please start a new thread for your issue.
