ā02-01-2010 11:46 AM
Hello friends,
In IPM i have discovered all devices fron CS but only 4 are IP SLA enabled,It is showing for 3switches 3560 POE switch
Model SW Version SW Image
WS-C3560G-48PS 12.2(35)SE5 C3560-IPBASE-M
and for 1 No's 2960
c2960-lanbasek9-mz.122-44.SE6/c2960-lanbasek9-mz.122
-44.SE6.bin"
It is not showing me on my core switches,Can u tell me which version of IOS is needed to support IP SLA or i missing something to enable it. The SnmP Read/write credentials are correct
ā02-01-2010 01:29 PM
Make sure you are using an IOS image that supports IP SLA. Use the feature navigator to find out:
www.cisco.com/go/fn
ā02-08-2010 12:32 AM
Some of the IP SLA features are supported on 6500 IOS listed below:
s3223-ipbase_wan-mz.122-18.SXF16.bin |
Still it is not showing me in the IPM as a IP SLA feature enabled ?????
Awaiting ur replies friends.
ā02-08-2010 11:42 PM
Hello clarke,
Can u help me for the above mail query.
ā02-09-2010 11:57 AM
Any suggestion clarke
ā02-10-2010 12:35 PM
Can anybody help me for the query of above mail.
