IP SLA not showing "packet loss"
ullasupendran
Hello friends
I am facing some IP SLA implementation issues. I trying to test my requirement in a LAB scenario.
My network is R1--->R2 .I am configuring UDP jutter feature of IPSLA on these routers.R1 is the source and R2 is the Responder. When i see the "show ip sla statistics" i see the packet loss always 0 ,even if i shut down the interfaces of the connected routers while doing a continuous ping . Rest of the values like jitter,RTT are showing up fine. Kindly let me know your views on this problem.
ullas
srimural
A sample config is given below. Just verify the configs on ur end.
ip sla monitor
type udpEcho dest-ipaddr X.X.X.X dest-port
frequency 30
request-data-size 160
tos 128
timeout 1000
tag FLL-RO
ip sla monitor schedule 5 life forever start-time now
Please give the o/p of the following commands
show ip sla monitor configuration
Thanks and Regards,
Srinath Muralidharan
Cable&Wireless
+919980930364
The current config and results are as flollows
ip sla 1
udp-jitter x.x.x.x 65051 source-ip x.x.x.x num-packets 15 interval 200
frequency 20
ip sla schedule 1 life forever start-time now
7200#sh ip sla statis
FL-OP-GRE-7200#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Latest RTT: 90 milliseconds
Latest operation start time: 09:58:33.760 EST Thu Nov 20 2008
Latest operation return code: OK
RTT Values:
Number Of RTT: 15 RTT Min/Avg/Max: 90/90/96 milliseconds
Latency one-way time:
Number of Latency one-way Samples: 15
Source to Destination Latency one way Min/Avg/Max: 62/62/69 milliseconds
Destination to Source Latency one way Min/Avg/Max: 27/27/29 milliseconds
Jitter Time:
Number of SD Jitter Samples: 14
Number of DS Jitter Samples: 14
Source to Destination Jitter Min/Avg/Max: 0/2/7 milliseconds
Destination to Source Jitter Min/Avg/Max: 0/1/1 milliseconds
Packet Loss Values:
Loss Source to Destination: 0 Loss Destination to Source: 0
Out Of Sequence: 0 Tail Drop: 0
Packet Late Arrival: 0 Packet Skipped: 0
Voice Score Values:
Calculated Planning Impairment Factor (ICPIF): 0
Mean Opinion Score (MOS): 0
Number of successes: 50
Number of failures: 0
Operation time to live: Forever
