IP SLA problem creating multioperation scheduler group using SNMP
Hello Forum,
until recently I successfully created multioperation scheduler groups using SNMP with e.g. the following procedure:
snmpset -cMYCOMMUNITY -v2c <router-ip> \
rttMonGrpScheduleAdminProbes.<group-id> s 100-200 \
rttMonGrpScheduleAdminPeriod.<group-id> i 60 \
rttMonGrpScheduleAdminStatus.<group-id> i 5
Then I activated the group by setting
rttMonGrpScheduleAdminStatus.<group-id> i 1
This worked well with the used IOS Versions 15.0(1r)M1 and 15.0(1)M2 on ISR platform 29xx and I suppose with much other ones...
But now I have an ISR 3945 running 15.2(2)T and an ISR 2801 running 15.1(3)T, these two spit out the following error:
wrongValue (The set value is illegal or unsupported in some way)
I could not find a related Bug in Cisco Bug Tool, so I am unsure: Is this a bug or has the procedure changed for configuring multioperation scheduler groups using SNMP?
It would be great if you could point me into the right direction.
Many thanks in advance!
194
