IP SLA UDP-Jitter Tests To C2811 Ver 12.3 rtr responder failing
I have a standalone router doing IP SLA udp-jitter tests to a number of various routers.  But udp-jitter tests to two routers are failing.
The failing tests are to two c2811s targets  running c2800nm-adventerprisek9-mz.123-14.T7.bin.   I enabled rtr responder on these two c2811s and I see that that they are receiving the udp-jitter incoming packets.
Does anyone know if rtr responder on the c2811 with IOS 12.3  can respond to IP SLA  udp-jitter tests ?    I suspect not but would like to know for sure.
Thx
gp
416
