Webcast-Catalyst9k
IPM 2.6.0.0 CLI EXPORT COMMAND
HI,
I need to export ipm statistics using the cli, but i Don't know how, if i use this command "ipm export -all 02/02/2012 07/02/2012" the process start but i don't have a file to read, i could really appreciate an command example to obtain a latency report with a daily format.
I am not used to this and IPM 2.6 is quite old, but here is the CLI reference for this version:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_internetwork_performance_monitor/2.6/user/guide/ipmcomm.html#wp1007017
the created files should reside either in the
     C:\Program Files\Internetwork Performance Monitor\
     or the TMP or TEMP directory of the server  (which I know is very imprecise...)
or in solaris under /opt/CSCOipm
Re: IPM 2.6.0.0 CLI EXPORT COMMAND
thanks a lot , i've found here
D:\program files\Internetwork Performance Monitor\Server\htdocs\reports
is it html the only format avaible?
the last question , i have some problem to use the correct syntax and until now i have not found exaples, in my case i use this: "ipm export -all mm/dd/yyyy mm/dd/yyyy" then i take the alert file , i would like to use a command to have the daily alert report without generate all the other reports.
235
