Community Member
IPM 2.6 crash and work really bad.
Hi, I am using IPM 2.6 with a lot of problems. IPM often crash, and I have to restart the process manualy o sometimes restart the system. I noted also IPM sometimes just don't collect statistic for 4/5hours and after start again, by itself. Other times like I told you I need to restart it.
Some of you have this kind of experence. Can you help to resolve this issue?
Thank you really much. Antonello.
1 REPLY
Community Member
Re: IPM 2.6 crash and work really bad.
Maybe the problem is the one described here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdz13783
If so, the bug is not resolved in IPM 2.6.
The workaround is to launch a script file that restart the IPM processes at regular interval (for example every 4/6 hours o every day).
The commands are:
ipm stop
ipm start
128
