IPM Collertor for HTTPS site
I am trying to monitor the connection to a site that uses https. But every time I try to add the address it gives me an error. If I use www instead of https it excepts the URL, but I need to use HTTPS.
Any help would be super.
Mike
Re: IPM Collertor for HTTPS site
IP SLA does not support HTTPS operations, only HTTP. The problem comes from the complexity involved with SSL and certificates. There is currently no plan to implement SSL support.
That said, you could create a simple TCP connect operation to port 443 of the server. The collector would not track page load time, but you could at least check TCP connection latency.
Thanks for the quick response. I will try that.
Mike
120
