IPM-Source Device
In IPM the source device list is not showing.Is there any thing to configure in the devices to be monitored?
Sachi
Silver
Re: IPM-Source Device
What version of IPM/LMS are you running?
Does the device that you're trying to add support IPSLA ? (easy to check, log into the IOS device and type in "sho rtr" and if you get "unrecongnized command" it doesnt)
Is IPSLA enabled ? (rtr enable in config mode to enable it)
Have you added the device into IPM ?
IPM version is 2.6
Device is 6500 IOS-s72033-ipservicesk9_wan-mz.122-33.SXH.bin
No rtr command in config mode
ipsla is there.
but to configure ipsla its asking source & dest device alongwith type (dhcp,jitter etc)
can u pls guide me what r the device type & IOS release supports rt enable(ipsla).
thanks
sachi
Silver
Ahh so I see you have sup 720's ! Good news a very good platform. you need an image with advanced IP services such as s720033-advipservicesk9_wan-mz.122-18.SXF5.bin.
You can look in the feature navigator of IOS to see which images fit.
131
