Community Member
IPMDbMonitor Process
When installing IPM 4.0.1, the manual says to check and make sure all 4 processes are running.
I am missing one. IPMDbMonitor
When calling up the devices in the module I get an error ....
Error in communicating with Group Administration Server.
Is there a way to patch this? Or should I uninstall IPM and then re-install?
1 REPLY
Re: IPMDbMonitor Process
This is fine. In LMS 3.0.1, we removed some extraneous dbmonitor processes to free more memory.
The error you're seeing has not do with IPMOGSServer being down or in a bad state. Please post the IPMOGSServer.log.
105
