03-26-2010 06:46 AM
Hi All
I need urgent help, I'm trying to set up an IPSLA operation which is failing and i need urgent help. I read and followed alot of documentation.
When i test UDPJitter trace oprtation this works fine without a problem, however when i try to use.
the basic jitter operation i get operation failures for some reason. Please see below.
This is the topology
R1--------------------R2
Source Responder
192.168.1.1 192.168.2.7
R1#
Mar 1 03:07:22.847: %SYS-5-CONFIG_I: Configured from console by console
R1#debug ip sla monitor trace 122
IP SLA Monitor TRACE debugging for entry 122 is on
Mar 1 03:07:29.579: IP SLA Monitor(122) CtrlMsg: Timeout
Mar 1 03:07:29.579: IP SLA Monitor(122) CtrlMsg: Sending msg, ver=1, id=123, le
n=52, cmd=4, ip=192.168.2.7, port=4052, duration=5200ms
R1#debug ip sla monitor error 122
IP SLA Monitor ERROR debugging for entry 122 is on
R1#
Mar 1 03:07:34.583: IP SLA Monitor(122) CtrlMsg: Timeout
Mar 1 03:07:34.583: IP SLA Monitor(122) CtrlMsg: No connection
Mar 1 03:07:34.583: IP SLA Monitor(122) Scheduler: Updating result
R1
ip sla monitor 122
type jitter dest-ipaddr 192.168.2.7 dest-port 4052 source-ipaddr 192.168.1.1 co
dec g711alaw codec-numpackets 100 codec-interval 2
ip sla monitor schedule 122 life forever start-time now
ip sla monitor 123
type pathJitter dest-ipaddr 192.168.2.7 num-packets 100 interval 2
ip sla monitor schedule 123 life forever start-time now
R2
ip sla monitor responder
R2#show ip sla monitor responder
IP SLA Monitor Responder is: Enabled
Number of control message received: 0 Number of errors: 0
Recent sources:
Recent error sources:
03-26-2010 06:57 AM
you get "Mar 1 03:07:34.583: IP SLA Monitor(122) CtrlMsg: No connection" so is it possible that there is an ACL or firewall between your 2 routers?
you configured the port UDP 4052 as the destination port, so the control packets should be sent onUDP 4053.
03-26-2010 07:18 AM
Hi Memal
I don't have any firewall between the two devices.
Please tell me what the best configuration is. All i need is to just be able to measure UDP Jitter between 192.168.1.1 Source destination 192.168.2.7
The path jitter operation works without a problem.
Will the below work.
ip sla monitor 122
type jitter dest-ipaddr 192.168.2.7 dest-port 4052 source-ipaddr 192.168.1.1 source-port 4053 codec g711alaw codec-numpackets 100 codec-interval 2
ip sla monitor 123
03-26-2010 07:21 AM
Hi Memal
ip sla monitor 122
ip sla monitor 123
