Is Cisco Prime Infrastructure 1.2 or 2.0 compatible on UCS ?
hello, can we install Cisco Prime Infrastructure 1.2 or 2.0 on UCS C22, C220M3 or NCS Hardware Appliance without using VMware ?
thanks.
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Unfortunately, this isn't yet supported for Prime Infrastructure.
you have Installed VMWare first.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hardaware does not come with VMware. you need to installed VM on top of it.
Thanks-
Afroz
Thanks-
Afroz
hi, what about the NCS hardware appliance, does it come with VMware because in the configuration tool i don't see the VMware license but i can check Cisco Prime 2.0 ! .
thanks.
Thanks-
Afroz
thanks a lot.
254
